Is there an FE module for 2620XM?
jamesellis
I've been digging for a fast ethernet module for a 2620XM and only find discontinued items.
Anyone know of a current supported module?
Hello James,
AFAIK, you can only get 2 FE interfaces together with the 2WIC module, if you want to get only Ethernet, you can get the 1 or 4-port Ethernet module, but not FastEthernet:
LAN Network Modules
NM-1GE 1-port Gigabit Ethernet Network Module
NM-1FE-FX 1-Port Fast Ethernet Network Module, FX Only
NM-1E 1-Port Ethernet Network Module
NM-4E 4-Port Ethernet Network Module
LAN and WIC Combo Network Modules
NM-1FE2W 1 10/100 Ethernet 2 WAN Card Slot Network Module
NM-2FE2W 2 10/100 Ethernet 2 WAN Card Slot Network Module
HTH,
Georg
I saw these two wic modules, but all the documentation makes you think the NM-1FE2W and NM-2FE2W only work in the 3600's.
I have a 2FE2W and my 2620 will not recognize it. Makes me believe there are no FE modules out there, really irritating.
Any ideas?
There is the NM-16ESW and it's cousin the NM-16ESW-1GIG. The only catch is that you have to have at least an IP Basic feature set. It gives you the ability to add more ports by grouping the physical ports into router addressable VLANs.
-Mike
I read several accounts of people installing the NM-1FE in models such as the 2610. If it will work in that machine, it will certainly work in the 2620.
Joe
