Load balancing on Router (Traffic management)
ravillal
Beginner
Beginner
Hi Experts,
One quick question. ( I hope this is easy). I would like to be able to load balance internet traffic on a Cisco 2621XM running IOS version 12.2(8)T5. My goal is the following:
Send 75% through 1 ISP and 25% to a second ISP.
What would be the commands to do this?
I'm not using any routing protocol.
Make up config can be like this:
Inside network: 192.168.1.0
Outside Interface of router S0/0: 200.1.1.1
Outside Interface of router S0/1: 200.2.2.2
Let us pretend that we want to send 75% of the traffic through serial S0/1 ip 200.2.2.2
Randall
spremkumar
Engager
Engager
If its connecting to same isp u can very well mention backup interface and backup load commands on the primary so that secondary interface will take the load once after the primary link touches 75% of the total b/w value configured.
Since its connecting to 2 Different ISPs revert back whether u r running BGP peering with your SPs ??
regds
prem
Hi Prem,
I'm not using BGP, and I think that the service provider doesn't support it? Any other workaround that I can try?
Randall
Recognize Your Peers
