Load balancing over static routes
saimbt
Is there a way to achieve Load Balancing using static routes over point to point links??
-Sai.
6 Replies 6
manojkreddy
hello Sai,
are those pt to pt links are being terminated on same routers at both end?
if yes, u can do it by creating a multilink interface (group) at both ends and configure the two interfaces at each end to be members of the multilink group.
don't give ip address to serial interfaces. give an ip address to multilink interface.
point your static route to IP address of your next hop multilink interface
reply if u need commands to do it.
manoj.
Hello Manoj, My ISP has provided me with the IP address for both my T-1s. So, how do I config multilink and what IP add do I use for my multilink?
Thanks!
manoj, will this work for VOIP too,,
mikegallagher
As long as the statics have equal metrics to the same destination networks, the traffic will be load balanced. By default, on a per-destination basis. You can change it to per-packet if you wish.
HTH,
Mike
Harold Ritter
Just configuring a static route to the next-hop address on each of the PPP links should be enough to achieve loadbalancing.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Hritter,
U mean to say, default routes to the next-hop address on each of the PPP links is enough, am I right???
