minimal interframe gaps in gigabit ethernet port
amms68958
Hi ,
Whether someone know the minimum interframe gap in gigabit ethernet port in Cisco switch ,3750.
Also ,would like to know the IEEE standard for the same.
Thanks in advance,
Thomas.
gpulos
Level 8
Level 8
the interframe gap for 1-GB is 96 nanoseconds of 96 bit size.
the minimum IFG for is 96 bit times. (the time it takes to transmit 96 bits of data at the specified data rate)
ie:
10Mbps - 9.6 milliseconds
100Mbps - 960 nanoseconds
1000Mbps - 96 nanoseconds
note: you may not want to decrease an IFG smaller than 9.6 microseconds if all other hosts are only capable of 9.6 ms. (10mbps connections)
interframe gap shrinkage could occur to the point where the gap is too small.
if you have a gap that is too small, it will not allow the NIC enough time to switch between TX/RX states and packets could be lost.
please see these links for more IFG info:
http://www.ethermanage.com/ethernet/ch13-ora/ch13.html
http://www.cisco.com/univercd/cc/td/doc/cisintwk/ito_doc/ethernet.htm
rajinikanth
Level 3
Level 3
time gap between two frames in gigabit ethernet port is 96 nanoseconds
