Native IOS Upgradtion 6500 with Two Sup Engine
tarun209
Hi Friends
I got a Cisco Catalyst 6509 Switch with two SUP-2 Engines and Two MFSC cards.We are planning to do a ios upgrade .Can somebody suggest the way to it in this redundant environment.
Thanks&Regards
Tarun G
You mentioned you are running Native IOS. If you are running Native IOS, there is no need to upgrade your MSFCs separately. Can you paste an output of sh mod from your switch just to be sure you are not confused with hybrid and Native OS
ybajpai
There is a document written out there just for you! :)
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a0080116ff0.shtml#maintask3
Hope this helps!
Prashanth Krishnappa
What IOS you are running currently. Copy the new image to sup-bootflash(or external flash cards) of both supervisors. You can power cycle the switch for the new IOS to kick in. If you are using RPR redundancy, you could do a Fast Software upgrade
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/12_1e/swconfig/redund.htm#wp1089399
The document is very helpful.I want to know that For MFSC cards we need to upgrade the IOS separately or we just need to upgrade the IOS present in sup engines and that will do.The question i am asking is because the below document in case of single sup engine and single MFSC suggest to upgrade IOS Seprately.Please Suggest.
Thanks & Regards
Tarun G
