03-12-2010 10:02 AM - edited 03-03-2019 05:53 AM
we are trying to get a UPS for a 6509 switch which has 2 x 3000w PS. can anyone recommend me how much kva ups like 3kva or 5 kva ups can be deployed
Karthik
Solved! Go to Solution.
03-12-2010 12:51 PM
First you need to work out your power draw:
Once done try the UPS selector from APC (obviously once you have a spec, you can go elsewhere to buy...).. this will let you specify how much power your kit will draw, and how much runtime you want on UPS etc.
http://www.apc.com/sizing/selectors.cfm
Aaron
Please rate helpful posts...
03-12-2010 12:51 PM
Aaron
03-15-2010 10:14 AM
hi thanks for the responses that helped me a lot
Karthik
03-15-2010 10:58 AM
No problem - please remember to rate posts using the stars and mark answered if they are resolved.
Aaron
03-13-2010 12:12 AM
Karthik
Hi Karthik,
Check out the below link hope to help !!
http://www.cisco.com/univercd/cc/td/doc/pcat/ca6000.htm
Remember to rate helpful post
Ganesh.H
