Routing Protocol
caijunjie
That say I have 3 router and I want to enable RIP routing protocol. Do I have to configure RIP on all 3 router ?
PLs advice. THanks in advance..
thisisshanky
Level 11
Level 11
Yes, thats correct. You have to enable on all 3.
router rip
network x.x.x.x
version {1|2}
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thanks for your advice.
sumanthmyneni
On three of your routers,you need to configure rip.In rip there are two versions.version 1 will be accepted where vlsm is not used.vr.2 can be used where vlsm is used.hope you wouldn't use vlsm,so rip ver.1 will have to be configured on all the 3 routers
amikat
Level 7
Level 7
Strictly saying you do not have to configure on all 3 routers. For example you can have static routing between 2 of them and do redistribute static to RIP in between.
