serial interface speed check
milan.kulik
Level 10
Level 10
does anybody know how to check the actual speed on a DTE serial port?
I've got my Cisco 1600 connected to a provider DCE which provides the clock.
I'd like to check that the speed is correct.
I think that sh controllers serial 0 should show the actual interface speed but the command output shows just some hex numbers and I haven't found any explanation on CCO.
Milan
rsissons
Level 5
Level 5
Unfortunately there is no way to determine exactly what the speed a serial line is running at on a 1600.
The best you can do is to use the input and output byte counts for the last 5 minutes to see if they match the utilisation figure which is calculated using the configured bandwidth statement. If they match, then the bandwidth is correct.
