Troubleshooting Serial interface
j.vashee
I have a wide area point to point connection via frame relay. The interface on my backbone router is UP/UP. My frame relay PVC is also active. The Serial interface at the router at the other end is also UP / UP. But the Sub interface is Down/ Down.
I have checked the IP addressess ; Encapsulation ; DLCI's and it seems to have been configured correctly
Anyone got any ideas what the problem could be.
Thanks in advance.
Jay
17 Replies 17
jmia
Level 7
Level 7
Can you post your config pls.
Thanks -
interface Serial0
description 1024Kb/s Frame Relay to xxxxxxxxx
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
frame-relay lmi-type ansi
interface Serial0.1 point-to-point
description PVC to xxxxxxxxxxx
bandwidth 1024
ip address xxxxxxxxx
no cdp enable
frame-relay interface-dlci 106
xxxxxxxxxx#sh ip int brie
FastEthernet0
Serial0 unassigned YES NVRAM up up
Serial0.1 xxxxxxxxxxxxxxx YES NVRAM down down
Other end.
interface Serial4/1/3
description Connection to xxxxxxxxx
no ip address
no ip directed-broadcast
ip route-cache distributed
interface Serial4/1/3.1 point-to-point
description xxxxxxx
bandwidth 1024
ip address xxxxxx
ip access-group xxxx in
traffic-shape rate 1024000 25600 25600 1000
no cdp enable
frame-relay interface-dlci xxx
Hi -
I presume you've tried no shutdown cmd on se0.1 ?
I.e. router(config) int se0.1
> router(config-subif) no shutdown
thanks -
Yes tried that and reloaded router as well
Can you please post the output from the command show frame-relay PVC? and the output from the command show controllers serial X from both routers?
xxxxxx#sh frame-relay pvc
PVC Statistics for interface Serial0 (Frame Relay DTE)
Active Inactive Deleted Static
Local 0 0 1 0
Switched 0 0 0 0
Unused 0 0 0 0
DLCI = 106, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial0.1
input pkts 0 output pkts 1 in bytes 0
out bytes 80 dropped pkts 0 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
xxxxxxxx#sh controllers serial 0
Interface Serial0
Hardware is PowerQUICC MPC860
DTE V.11 (X.21) TX and RX clocks detected.
idb at 0x80BA5D28, driver data structure at 0x80BAD634
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0000, Mask [SCCM]=0x001F, Status [SCCS]=0x06
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x00008000
Mask [CIMR]=0x40204000, In-srv [CISR]=0x00000000
Command register [CR]=0x5C0
Port A [PADIR]=0x1000, [PAPAR]=0xFFFF
[PAODR]=0x0000, [PADAT]=0xE6FF
Port B [PBDIR]=0x09C0F, [PBPAR]=0x0E00E
[PBODR]=0x00000, [PBDAT]=0x0847C
Port C [PCDIR]=0x000, [PCPAR]=0x000
[PCSO]=0xC20, [PCDAT]=0xFCC, [PCINT]=0x000
Receive Ring
rmd(FF002230): status 9000 length 10 address 196B604
rmd(FF002238): status 9000 length 10 address 196AF84
rmd(FF002240): status 9000 length 10 address 196A904
rmd(FF002248): status 9000 length 10 address 196A284
rmd(FF002250): status 9000 length 10 address 1970404
rmd(FF002258): status 9000 length 10 address 1970A84
rmd(FF002260): status 9000 length 10 address 196FD84
rmd(FF002268): status 9000 length 10 address 196F704
rmd(FF002270): status 9000 length 10 address 196EA04
rmd(FF002278): status 9000 length 10 address 196E384
rmd(FF002280): status 9000 length 10 address 196DD04
rmd(FF002288): status 9000 length 10 address 196D684
rmd(FF002290): status 9000 length 10 address 196D004
rmd(FF002298): status 9000 length 10 address 196C984
rmd(FF0022A0): status 9000 length 10 address 196C304
rmd(FF0022A8): status B000 length 10 address 196BC84
Transmit Ring
tmd(FF0022B0): status 5C00 length E address 197FF94
tmd(FF0022B8): status 5C00 length E address 197FF94
tmd(FF0022C0): status 5C00 length E address 197FF94
tmd(FF0022C8): status 5C00 length E address 197FF94
tmd(FF0022D0): status 5C00 length E address 197FF94
tmd(FF0022D8): status 5C00 length E address 197FF94
tmd(FF0022E0): status 5C00 length E address 197FF94
tmd(FF0022E8): status 5C00 length E address 197FF94
tmd(FF0022F0): status 5C00 length E address 197FF94
tmd(FF0022F8): status 5C00 length E address 197FF94
tmd(FF002300): status 5C00 length E address 197FF94
tmd(FF002308): status 5C00 length E address 197FF94
tmd(FF002310): status 5C00 length E address 197FF94
tmd(FF002318): status 5C00 length E address 197FF94
tmd(FF002320): status 5C00 length E address 197FF94
tmd(FF002328): status 7C00 length E address 197FF94
SCC GENERAL PARAMETER RAM (at 0xFF003C00)
Rx BD Base [RBASE]=0x2230, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x22B0, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x18008440, BD Ptr [RBPTR]=0x2270
Tx State [TSTATE]=0x18000548, BD Ptr [TBPTR]=0x2328
SCC HDLC PARAMETER RAM (at 0xFF003C38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=65464
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
0 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
PVC Statistics for interface Serial4/1/3 (Frame Relay DTE)
DLCI = 103, DLCI USAGE = LOCAL, PVC STATUS = ACTIVE, INTERFACE = Serial4/1/3.1
input pkts 0 output pkts 210 in bytes 0
out bytes 19060 dropped pkts 0 in FECN pkts 0
pvc create time 04:22:15, last time pvc status changed 04:21:15
I could not do the show controller on the other router.
WARW1BR2#sh int s4/1/3
Serial4/1/3 is up, line protocol is up
Hardware is cyBus Serial
Description: Connection to *********
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 255/255, load 1/255
Encapsulation FRAME-RELAY IETF, crc 16, loopback not set
Keepalive set (10 sec)
LMI enq sent 70366, LMI stat recvd 70366,LMI upd recvd 0, DTE LMI up
LMI enq recvd 0, LMI stat sent 0,LMI upd sent 0
LMI DLCI 0 LMI type is ANSI Annex D frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:05, output 00:00:05, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
81113 packets input, 1961924 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
70601 packets output, 1005548 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
1 carrier transitions
RTS up, CTS up, DTR up, DCD up, DSR up
Q. Why is your PVC on se0.1 showing deleted ?
I think because the sub interface S0.1 is not receiving any lmi's. This is only my assumption. Thanks
Hi -
I think you've answered your own question, if you have no LMI then you have no PVC so as the other post suggested please check with service provider of on this issue.
thanks -
Is this a new circuit or an old one?
If this is a new circuit verify with the service provider that the PVC has been provisioned correctly.
It is a new circuit. The provider has verified and confirmed that the PVC is correctly provisioned. Thanks
Hi again -
Do a "sh fr lmi" and post the result please -
Thanks -
LMI Statistics for interface Serial4/1/3 (Frame Relay DTE) LMI TYPE = ANSI
Invalid Unnumbered info 0 Invalid Prot Disc 0
Invalid dummy Call Ref 0 Invalid Msg Type 0
Invalid Status Message 0 Invalid Lock Shift 0
Invalid Information ID 0 Invalid Report IE Len 0
Invalid Report Request 0 Invalid Keep IE Len 0
Num Status Enq. Sent 70548 Num Status msgs Rcvd 70548
Num Update Status Rcvd 0 Num Status Timeouts 0
*******#SH FRame-relay LMI
LMI Statistics for interface Serial0 (Frame Relay DTE) LMI TYPE = ANSI
Num Status Enq. Sent 319 Num Status msgs Rcvd 319
Can you post the output for the command debug frame-relay lmi?
thanks
