Using a router as an Internet connection sharing device
rialam
I would like to use a router 1605-R to share a dial-up connection to the internet. This router has an ethernet port which I can configure easily. It's also got a serial interface to which is connected an analog modem via a DTE RS-232 - DB60 cable.
This router is connected to a hub via its LAN interface. On the same hub, computers are also connected & have IP addresses on the same subnet as the IP address of the LAN interface of the router and are configured to use this same LAN interface as a gateway.
My question is: how do I configure the serial interface (step by step) so that any request from any computer to a web address causes the router to start the dial up connection to Internet via the analog modem.
I urgently need help on this!!!
Thank you.
16 Replies 16
lgijssel
Level 9
Level 9
I have a fairly simple config which contains all configuration except for the modem control. Hope it helps a bit to understand about NAT and ip routes.
hostname Internet
enable password removed
ip subnet-zero
ip name-server x.x.x.x
interface Ethernet0
ip address 172.16.4.6 255.255.0.0
no ip directed-broadcast
ip nat inside
interface serial0
ip address x.x.x.x 255.255.255.252 (can also be ip negotiated)
ip nat outside
no cdp enable
encapsulation ppp
ip nat inside source list 1 interface serial0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 serial0
access-list 1 permit 172.16.0.0 0.0.255.255
line con 0
transport input none
line vty 0 4
access-class 1 in
password removed
login
end
Thanks for your help.
Yet, how come you don't supply any username nor password for your router to authenticate to the ISP? Also, the router should cause the modem to dial the ISP phone number. Where is that?
On which IOS version is NAT available? Can I update my IOS version somewhere from Cisco website in case it doesn't support NAT?
Riadh.
Below is a sample config that you can try:
interface ethernet0
ip address 10.10.10.254 255.255.255.0
ip nat inside
interface serial0
physical-layer async
no ip address
encapsulation ppp
async mode dedicated
dialer pool-member 1
interface dialer1
ip address negotiated
encapsulation ppp
dialer wait-for-carrier-time 30
dialer string
dialer pool 1
dialer-group 1
ppp pap sent-username password
ip nat outside
ip nat inside source list 100 interface dialer 1 overload
ip route 0.0.0.0 0.0.0.0 dialer1
access-list 100 permit ip 10.10.10.0 0.0.0.255 any
dialer-list 1 protocol ip list 100
Goodluck!
Thanks for your config.
Two commands were not accepted on my router:
- physical-layer async
- async mode dedicated
Still no luck. I guess because of the 2 above commands!!!
The router I have is a cisco 2620.
Any other advice.
Thanks again.
The "physical-layer async" command can be used for the serial interface
of a Cisco 1600 router. You mentioned in your first post that you wanted
to use a 1605-R router that's why I assumed you have a Serial WIC installed
on the 1605's WIC slot. It would be better if you could post the output
of the following:
- show version
- show diag
- show run
We have to check if the serial interface(s) of your router are
capable of running async. If you have typed the "physical-layer async"
command under the serial interface, that interface could probably
be SYNC capable only. The output of the commands above will help us
to verify this assumption. Thanks.
Yeah, that's right, I mentioned that I had a 1605-R router but that one did not accept ip nat commands. That's why, I tried on a separate 2620.
The 1605 accepted the physical-layer async & not the ip nat, whereas the 2620 accepted the ip nat but not the physical-layer command.
I'll send the result for your above commands in separate posts.
Thanks a lot for your help.
For the 2621
- Show ver gives:
IOS (tm) C2600 Software (C2600-IK9O3S-M), Version 12.2(6a), RELEASE SOFTWARE (fc
1)
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Sat 01-Dec-01 20:52 by pwade
Image text-base: 0x80008088, data-base: 0x8120F8B8
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
Router uptime is 8 minutes
System image file is "flash:c2600-ik9o3s-mz.122-6a.bin"
cisco 2621 (MPC860) processor (revision 0x600) with 60416K/5120K bytes of memory
Processor board ID JAD05450T6X (4029363579)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
- Show diag gives
Slot 0:
C2621 2FE Mainboard Port adapter, 3 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 6.0
PCB Serial Number : JAD05450T6X (4029363579)
Part Number : 73-3200-10
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : B0
Deviation Number : 0-0
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 A2 41 06 00 C1 18 4A 41 44 30 35 34
0x10: 35 30 54 36 58 20 28 34 30 32 39 33 36 33 35 37
0x20: 39 29 82 49 0C 80 0A 04 00 81 00 00 00 00 42 42
0x30: 30 80 00 00 00 00 FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.1 Board revision E0
Serial number 7037567 Part number 73-1775-02
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 1
0x20: 01 02 01 01 00 6B 62 7F 49 06 EF 02 00 00 00 00
0x30: 70 00 00 00 98 01 21 01 FF FF FF FF FF FF FF FF
I only have one Serial WIC card. So you may find it's the same serial number on 1605-r & 2621.
Thanx
For the 1605-r
- show version gives:
IOS (tm) 1600 Software (C1600-NY-M), Version 11.2(11)P, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Tue 06-Jan-98 06:34 by dschwart
Image text-base: 0x02005000, data-base: 0x023564C8
ROM: System Bootstrap, Version 11.1(12)XA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
ROM: 1600 Software (C1600-RBOOT-R), Version 11.1(12)XA, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
Router uptime is 14 minutes
System restarted by power-on
System image file is "flash:c1600-ny-mz.112-11.P", booted via flash
cisco 1605 (68360) processor (revision C) with 15872K/512K bytes of memory.
Processor board ID 07708118, with hardware revision 00000000
Bridging software.
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 Ethernet/IEEE 802.3 interface(s)
1 serial(sync/async) network interface(s)
System/IO memory with parity disabled
8192K bytes of DRAM onboard 8192K bytes of DRAM on SIMM
System running from RAM
8K bytes of non-volatile configuration memory
2048K bytes of processor board PCMCIA flash (Read/Write)
show diag gives:
Serial number 0007037567 Part number 73-1775-02
Test history 0x00 RMA number 00-00-00
Connector type WAN Module
0x00: 01 02 01 01 00 6B 62 7F 49 06 EF 02 00 00 00 00
0x10: 70 00 00 00 98 01 21 01 FF FF FF FF FF FF FF FF
2620 ver & diag follow soon!!!
From the show diag of your 2600, I believe the WIC-1T installed in slot 0
only supports synchronous communication when installed in the 2600 router.
That's why it does not support the 'physical-layer async' command.
Unless you're going to install a module or card that supports ASYNC,
you can probably use the AUX port of your router to dial-in to the ISP.
The following link could be used as a reference on how to configure
dialout using the AUX port:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_configuration_example09186a0080094579.shtml
Goodluck.
And thanks again for your help.
Why then does it say, under the 1605-r show ver:
- 1 serial(sync/async) network interface(s)?
I'll try with the aux port and I'll get back to you.
I tried to combine in some way the 1st config you sent me to the CISCO document you linked in your last message.
The result is this:
Building configuration...
Current configuration : 1375 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
enable secret 5 $1$gOGe$gBJ0TptVLcON9r9wzsTuj/
ip subnet-zero
ip audit notify log
ip audit po max-events 100
ip ssh time-out 120
ip ssh authentication-retries 3
chat-script Dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 45 connect \c
call rsvp-sync
interface FastEthernet0/0
ip address 192.168.0.10 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Async65
no ip address
encapsulation ppp
dialer in-band
dialer pool-member 20
async default routing
interface Dialer10
ip nat outside
encapsulation ppp
dialer pool 20
dialer string 1616
dialer-group 1
ppp pap sent-username ataj password
ip nat inside source list 100 interface Dialer10 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer10
ip http server
ip pim bidir-enable
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
dial-peer cor custom
line con 0
line aux 0
script dialer Dialout
modem InOut
modem autoconfigure type default
transport input all
stopbits 1
speed 57600
flowcontrol hardware
line vty 0 4
login
no scheduler allocate
end
When I ping any external IP address, the modem dials the number & the connection is established but nothing more than that. Success rate is 0 percent & ht elink goes down after a few seconds.
Is there anything missing in my configuration?
I suspect my problem is related to these missing three lines:
aaa new-model
aaa authentication login default local
aaa authentication login NO_AUTHEN none
aaa authentication ppp default local
These lines are available on the link you sent me: Configuring Dialout using a modem on the AUX Port. They mean nothing to me. That's why I want to know what they're for before I add them. 'Cause on that document it says "--- This is the basic AAA configuration for PPP calls."
I'm getting there thanks to your HELP :)
One last question: How can I make the modem only dial out? I don't want it to accept calls when the line receives an incoming call.
"When I ping any external IP address, the modem dials the number & the
0 percent & ht elink goes down after a few seconds."
Just to be sure that there are no problems with the user account
that you are using, please verify that you can connect to the
ISP using a PC and that account. Also check the ip address given
to the host PC and verify that you can browse the web.
You mentioned that the connection was established but goes down after
a few seconds. Were you able to check that you have acquired an IP address
from the ISP? It might be that the connection was not fully established.
It can be verified by the following debugs:
debug ppp negotiation
debug ppp authentication
I believe you don't need the AAA lines to perform a dial-out correctly.
Those lines are to be used to authenticate incoming calls and login.
"How can I make the modem only dial out?"
Typically, for this scenario, I use the command "modem inout" to perform
dialout. From the documentation, it mentioned that, by default, incoming
calls are not permitted (see the link below),
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122tcr/122tdr/drflcmo.htm#1112753
so could try removing the "modem inout" command and see if the router is
still able to perform dialout.
Basically, what we need are the debug output to check and verify where the
problem is. Thanks.
