Vlan configuration problem
lawwm
Hi guys,
I am having this problem. I can't remove the Vlan configuration. Since I am using Flat network(Vlan1). I would like to remove the configuration below.
vlan 1
tb-vlan1 1002
tb-vlan2 1003
vlan 1002
tb-vlan1 1
tb-vlan2 1003
vlan 1003
(vlan)#show cur
VLAN ISL Id: 1
Media Type: Ethernet
VLAN 802.10 Id: 100001
State: Operational
MTU: 1500
Backup CRF Mode: Disabled
Translational Bridged VLAN: 1002<<
Translational Bridged VLAN: 1003<<
Remote SPAN VLAN: No
VLAN ISL Id: 1002
Media Type: FDDI
VLAN 802.10 Id: 101002
State: Operational
MTU: 1500
Translational Bridged VLAN: 1<<
VLAN ISL Id: 1003
Media Type: Token Ring
VLAN 802.10 Id: 101003
State: Operational
MTU: 1500
Maximum ARE Hop Count: 7
Maximum STE Hop Count: 7
Would appreciate if you could guide me how to remove this vlan configurations. Thanks
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA2, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sun 07-Nov-04 23:14 by antonino
Image text-base: 0x80010000, data-base: 0x8055E000
ROM: Bootstrap program is C2950 boot loader
2950 uptime is 18 minutes
7 Replies 7
amit-singh
Level 8
Level 8
Got to Vlan database on your switch and use the command " no vlan 1003 tb-vlan1 tb-vlan2 ". This will work and take care of the problem.
HTH,
-amit singh
Hi Amit,
Thank for your replied.
vlan database
% Warning: It is recommended to configure VLAN from config mode,
as VLAN database mode is being deprecated. Please consult user
documentation for configuring VTP/VLAN in config mode.
29500(vlan)#no vlan 1003 tb-vlan1 tb-vlan2
Resetting translation bridge VLAN 1 to default
Resetting translation bridge VLAN 2 to default
2950(vlan)#exit
VLAN 1 TLB 2 VLAN 1003 has inconsistent TLB values (0 / 0)
APPLY failed.
Use 'abort' command to exit
2950(vlan)#
Too bad. I had tried this as well. Any clue?
Please try the following steps and let me know. Please use the command " apply " to save the changes before using exit. Make sure that your switch is set a VTP server.
vlan database
(vlan)#no vlan 1 tb-vlan1 tb-vlan2
(vlan)#apply
(vlan)#exit
Let me know how it goes...
-amit singh
Hi Amit,
Couldn't remove. Any clue?
(vlan)#apply
VLAN 1002 TLB 1 VLAN 1 has inconsistent TLB values (0 / 0)
APPLY failed.
(vlan)#
Please paste the output of "show curr " and show VTP status ".
the above message "VLAN 1002 TLB 1 VLAN 1 has inconsistent TLB values (0 / 0)" shows that there is a translation for vlan 1002 to vlan1. Try to use the same command to remove the translation to vlan 1002.
no vlan 1002 tb-vlan1 tb-vlan2
regards,
-amit singh
These are default vlans , you cannot remove them.
1002-1005
Normal
Cisco defaults for FDDI and Token Ring. You cannot delete VLANs 1002-1005.
amit,
It's worked. Thanks a lot.
Have a good weekend:)
Mun
