WS-X6704-10GE Problem
paul.kyte
I have a Catalyst 6509 with supervisor 720-3B and IOS 12.2(17d)SXB10. I have installed a X6704 4 port 10Gb card in slot 1 and powered up the system. The X6704 is recognised but is powered off with a message stating that it is not supported. Using show module the online daig status is unknown and the detals for the card are as follows:
HW FW Sw Status
1.5 12.2(14r)S5 12.2(17d)SXB Other
I have tried using alternate IOS levels such as 12.2(18)SXD4 but get the following error messages:
%PM_SCP-SP-1-LCP_FW_ERR: System resetting module 1 to recover from error: Linecard received system exception
%OIR-SP-3-PWRCYCLE: Card in module 1, is being power-cycled Off (Module Reset due to exception or user request)
Can someone please tell me what is wrong and if its the IOS I'm using what level I need to support the card.
pkhatri
Level 11
Level 11
The WS-X6704-10GE requires one of the following:
– WS-F6700-DFC3BXL (3.30 A@42 V)
– WS-F6700-DFC3B (3.00 A@42 V)
– WS-F6700-DFC3A (3.00 A@42 V)
– WS-X6700-CFC (0.75 A@42 V)
Can you confirm that you meet the above requirements ?
Paresh
6 Replies 6
pkhatri
Level 11
Level 11
Paresh
Hi Paresh,
I don't think I have any of those cards. Using show module I have the following:
Mod Ports Card Type Model Serial No.
1 16 SFM-capable 16 port 1000mb GBIC WS-X6516A-GBIC SAL0715BHAR
2 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL08280B14
3 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL09465FNV
4 6 Firewall Module WS-SVC-FWM-1 SAD071903HF
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL09358QGZ
6 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL09475WKY
9 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL094448HW
Mod MAC addresses Hw Fw Sw Status
1 0009.11f7.ff90 to 0009.11f7.ff9f 1.0 7.2(1) 8.3(0.156)RO Ok
2 0011.5ccf.08b0 to 0011.5ccf.08b3 1.5 12.2(14r)S5 12.2(18)SXD7 PwrDown
3 0015.f998.2e38 to 0015.f998.2e67 1.1 7.2(1) 8.3(0.156)RO Ok
4 0003.feab.7538 to 0003.feab.753f 2.0 7.2(1) 2.3(3)2 Ok
5 0013.7f0a.e194 to 0013.7f0a.e197 4.4 8.1(3) 12.2(18)SXD7 Ok
6 0015.f943.e990 to 0015.f943.e9bf 1.1 7.2(1) 8.3(0.156)RO Ok
9 0015.c6c9.32a4 to 0015.c6c9.32d3 1.1 7.2(1) 8.3(0.156)RO Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B SAL09358QTN 2.1 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL09358N63 2.3 Ok
Mod Online Diag Status
1 Pass
2 Unknown
3 Pass
4 Pass
5 Pass
6 Pass
9 Pass
does this mean I need some extra kit to use the x6704 ?
Paul
Hi Paul,
The WS-X6704-10GE ships with a WS-X6700-CFC installed unless ordered with WS-F6700-DFC3BXL, WS-F6700-DFC3B, or WS-F6700-DFC3A, so you should be fine there.
Minimum software for the card is 12.2(17a)SX, so you are fine there as well.
Do you have a known good 6704 module that you can try in this switch, or another switch that you could install this linecard in?
-Bobby
I've removed the X6704 and inspected it. I cannot see any daughter card mouned on it, there is only the base card.
I remember reading on the cisco website that if not specified the x6704 comes with the CFC card but I can't find reference to this now. Anyone know where this is stated?
It looks like my supplier has shipped incorrectly.
In answer to your question Bobby, I have installed a XENPAK 10GB-SR module but it makes no difference. I do have another 6509 and another 6704 but I get the same problem.
Looks like I'm going to have to go back to the supplier and query.
Paul,
Thanks for the update, if there is no daughter card present, then that will certainly be a problem, so hopefully your supplier will rectify it.
-Bobby
mike
you have to install it on a supported slot.
on 6513 only slots above 8 accept it, see below:
sh module
1 8 Network Analysis Module WS-SVC-NAM-2 SAD100105JC
7 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAL09412GYP
8 2 Supervisor Engine 720 (Hot) WS-SUP720-3BXL SAL09337FV4
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL094024ZX
10 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL09402068
11 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL094235KU
12 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL09412GJU
