Bookmark
Subscribe
1392
802.1X and Hub Use
aalton
I'm trying 802.1x in the lab. It works fine connected directly to the switch port. However, when I try to connect through a hub it won't authenticate properly.
The debug messages tell me the following:
Aug 30 16:19:19: dot1x-err:Dot1x is supportedonly on Access,Routed and private-vlan host modes.Trunk port being Authorized!! something went wrong
Aug 30 16:19:19: dot1x-err:Port wouldn't come up. Failing authorization.
But the interface is an access port:
switch#sh run int fa0/5
Building configuration...
Current configuration : 136 bytes
interface FastEthernet0/5
switchport mode access
dot1x port-control auto
dot1x host-mode multi-host
spanning-tree portfast
end
Here is what I'm running:
switch#sh ver
Cisco IOS Software, C3550 Software (C3550-IPBASEK9-M), Version 12.2(25)SEB, RELEASE SOFTWARE (fc1)
Why would it think I'm running a trunk port? Is this some defensive mechanism to stop bypassing of 802.1x controls? If so, how can I get it to work with hubs without turning off 802.1x on that port?
Allan
ybajpai
how does your complete config looks like? do you have "aaa authentication dot1x default group radius" configured?
Can you test and see if you see this issue for win2k or non-Microsoft clients as well?
The config is a red herring but yes the RADIUS server is configured properly. Remember, this works just fine when you plug in the PC directly.
The issue at hand is the meaning of the debug messages. Why would they appear when connecting through a hub?
I have new information that may be of value for those who might run into this situation.
The problem I was having is somehow related to the hub I was using (Netgear DS104). I tried another hub of the same model and it too wouldn't allow connection. Yet when I use a 3Com hub everything works as I would expect it to. There may be some compatability issue with the Netgear hub that I'm not aware of and don't have time to research. Perhaps those layer 1 experts out there have some insight.
