how to capture specific port traffic in router interface
r.docuyanan
I have a router and I want to capture a specific application/port transaction coming in/out through its Serial0 interface.
What necessary debug commands do I need to capture such transactions say port 69. Also I wan't to limit the processor load of the router during the capture so as not to affect the production router.
Thanks!
5 Replies 5
r.docuyanan
Additionaly, I will just use the terminal monitor command and capture the screen output
an easy way would be to create access lists allowing port 69 and specifying the ´log´ option at the end of the access list. In your case (I assume you are referring to TCP/UDP port 69 for TFTP traffic), the access list would look like this:
access-list 101 permit tcp any any eq 69 log
access-list 101 permit udp any any eq 69 log
access-list 101 permit ip any any
Then apply the access list to the interface in both directions:
interface serial0
ip access-group 101 in
ip access-group 101 out
HTH,
Georg
Thanks Georg, I try it. Will I be able to see it using terminal monitor with debug?? no more debug commands associated with it?
debug ip packet detail [ACL number] will show all the massages on your terminal monitor.. but if i were you.. i won't do that.. because you may get lots of message on your Terminal.
Use Georg suggestion.. log everything to you syslog server.
You will need to disable fast switching to capture all traffic by issuing the following command 'no ip route-cache' under the interface. Do not forget to re-activate fast switching after your trace since all packets will use process switch during the trace.
Nadine.
