have you tried configuring two vlans on inteface with dhcp
c.goona
Hi All I need to create a internet segment on a pix for visitors to my office. I need the interface to hand out ip addresses(dhcp).problem is my pix 515 has all interfaces in use.
Can i set up 2 vlans on 1 interface and the use dhcp on the pix on one of the vlans?
I dont have a spare pix to try this out, anyone done this or can you try it for me?
scoclayton
Level 7
Level 7
Yes, you can now configure DHCP server instances per interface. Makes no difference if these are physical interfaces or logical interfaces.
Hope this helps.
Scott
Thanks Scott i managed to get my hands on a pix firewall yesterday and try the commands for myself. It worked fine.
regards
colin goona
Colin,
What commands were used? Can you please advise?
Thanks.
PF
For the dhcp i used:
dhcpd address 192.168.100.2-192.168.100.100 vlan2
dhcpd dns 192.168.200.3
dhcpd wins 192.168.200.3
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain rdigest.com
dhcp enable vlan2
For the vlans look at this link for a realy good explanation http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172786.html#1113411
