05-27-2011 04:01 PM - edited 03-01-2019 02:26 PM
I was installing two Subscriber Manager with Veritas Cluster Server. The installation is ok, the problem is when I try to import subscribers database of other SM that are currently in production.
Once that I load database on the active Subscriber Manager and I try to import the output is following:
[pcube@sm04 ~]$ p3subsdb --import -f 201105271200.csv
Validating subscribers file ... 100% Validation found 992373 subscribers
Importing subscribers ... 100% Error - Failed to import from /opt/pcube/201105271200.csv
java.sql.SQLException: [TimesTen][TimesTen 7.0.5.2.0 ODBC Driver][TimesTen]TT0802: Data store space exhausted -- file "blk.c", lineno 3219, procedure "sbBlkAlloc"
[pcube@sm04 ~]$
Then, If I want to see the subscribers loaded in the SM:
[pcube@sm04 ~]$ p3db --num-of-subs
There are 444416 subscribers in the DB
Command terminated successfully
[pcube@sm04 ~]$
Only are loaded 444416 and not the complete database.
The replication schema is working fine, in standy SM the output is the same.
I hope your answers,
Thanks!.
Solved! Go to Solution.
05-30-2011 05:57 AM
Yes please change those values ("database_perm_size" and "database_temp_size") and remember to reload the server (cold boot) and the issue should reslove.
Working with Veritas does not have anything to do with it. Veritas is only providing redundancy. The issue is with the buffer memory for the subscribers.
Shelley.
05-30-2011 10:22 AM
Great! Please mark th thread as resolved and rate any responses that helped.
Shelley.
05-29-2011 05:43 AM
Hey Jaime,
This error usually comes when you dont have your max # of subscribers configured correctly or the temp memory is not set.
Not sure of version or platform but follow the attached guide and focus on the memory/subscriber settings and verify them for me once. Focus on the "Installation Procedures" section.
Shelley.
05-29-2011 02:24 PM
Thanks Shelley,
Regarding to the servers, these are RedHat Linux and SM version is 3.6.5. The max # of subscriber was setting in 1000000 on p3sm.cfg.
Reading the pdf file I can see that "database_perm_size" and "database_temp_size" not was modified for me in installation procedure, these are with default values.
Could be that my problem?. These values can be modified with SM already installed?.
Remember that this solution is working with Veritas Cluster Server.
Jaime.
05-30-2011 05:57 AM
Shelley.
05-30-2011 10:07 AM
I did the changes in "database_perm_size" and "database_temp_size" and now it works fine.
To make those changes, I had to add the following:
From “root” shutdown to TimesTen daemon
/opt/pcube/lib/tt/TimesTen/pcubesm22/startup/ tt_pcubesm22 stop
vi /var/TimesTen/sys.odbc.ini
PermSize=768
TempSize=256
From “root” startup to TimesTen daemon
/opt/pcube/lib/tt/TimesTen/pcubesm22/startup /tt_pcubesm22 start
and then reboot servers.
Thank you very much!
05-30-2011 10:22 AM
Shelley.
