Voice VLAN , Access VLAN, Switchport , SG350 Switch
Hi All!
I had a problem which is easy to some , i have an SG350 switch topo attached below the switch connect to Panasonic PBX port gi/50 , IP phone to port gi/6 , connected to other switches from gi 1,to 5, but the phone not registering , something wrong in my configuration.
Voice Vlan =20
Data Vlan=10
Configuration of the switch which connected to Panasonic PBX ,
config-file-header
Rack-01
v2.5.0.83 / RTESLA2.5_930_364_091
CLI v1.0
file SSD indicator excluded
unit-type-control-start
unit-type unit 1 network gi uplink none
unit-type-control-end
vlan database
vlan 10,20
exit
voice vlan id 20
voice vlan state auto-enabled
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
bonjour interface range vlan 1
hostname Rack-01
username admin password encrypted 004036d73f79edf1df016b146c4cd162dae1a012 privilege 15
interface vlan 1 ( for mgmt)
ip address 192.168.1.254 255.255.255.0
no ip address dhcp
interface vlan 20
name VOIP
interface GigabitEthernet1 (Other switch)
spanning-tree link-type point-to-point
switchport mode trunk
switchport trunk allowed vlan all
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface GigabitEthernet2 (Other switch)
interface GigabitEthernet3 (Other switch)
interface GigabitEthernet4 (Other switch)
interface GigabitEthernet5 (Other Switch)
interface GigabitEthernet6   (Panasonic IP Phone)
storm-control broadcast level 10
storm-control multicast level 10
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
spanning-tree bpduguard enable
switchport trunk allowed vlan add 20
switchport trunk native vlan 10
macro description ip_phone_desktop
macro auto smartport dynamic_type ip_phone_desktop
interface GigabitEthernet50   ( Panasonic port )
switchport mode access
switch port access vlan 10
exit
5 Replies 5
balaji.bandi
Check this thread may help you to resolve the issue : ( remove the macro or smart port information - that will help you)
https://community.cisco.com/t5/small-business-switches/sg350-28p-voice-and-data-vlan-config-on-a-single-port/td-p/4008018
BB
Thanks balaji I saw your reply on the other post before posting mine I did the same but I will turn off macro auto smart port and see what happen ,
Panasonic PBX port should be in
Switch port mode access
Switch port access vlan (DATA)
Is that right ??! Plz confirm
you want voice and Data on that port right . so you need add both the vlan to work.
BB
aha okay so the panasonic port will be considered as IP phone port  in configuration, to carry multiple traffic type ,
balaji.bandi
yes you right, test and advise.
BB
