Cisco 881 Software License Issue
zyang
I have been working with the 871 router and configuring it for work at home users.
Now we are purchasing and using the 881's instead.
I noticed that after write erasing the router, I need to run the command in the global config "license boot module c880-data level advipservices" just have eigrp.
However when I type show license, I get the following:
Index 1 Feature: advipservices
        Period left: 8  weeks 3  days
        Period Used: 2  hours 55 minutes
        License Type: EvalRightToUse
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Low
There is more but I left it out.  However it shows that the advipservices license has only 8 weeks and 3 days left.
What is this?  I thought that when I buy a brand new router, I should get everything, including IOS licenses.
So I would like to know is this a new licensing scheme and how does it get register and how do I get it so that the advipservices license is permanent?
Thank you.
Stephen Rodriguez
When you ordred the router, what IOS level did you indicate?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
daviswc_33
I am experiencing the same issue.  I am currently working with a C881W-A-K9 running 15.2(4)M3 from Cisco.  I did a show license on the device when I first consoled into it and saw that both the advipservices and advsecurity licenses were showing:
Period left: Life time
        License Type: Permanent
        License Priority: Medium
I began entering my config, and hit the "#>license boot module c800 level advipservices" command.  I then tried entering my eigrp configuration and none of the eigrp commands were showing up (no show ip eigrp, etc.).  I went back into the licenses and now my advipservices is showing:
        Period left: 8  weeks 4  days
        Period Used: 0  minute  0  second
        License State: Active, Not in Use, EULA accepted
Any help would be greatly appreciated.
I found my issue.  The devices that were ordered had the security license bundled, but not the ipadvservices, which were not ordered.  I am in the process of getting the appropriate licenses for the devices.
Ravi Singh
Level 7
Level 7
You can follow the below link for ordering software license issue.
http://www.cisco.com/en/US/prod/collateral/routers/ps380/white_paper_c11_499859.html
