CMX 10.2.3
moh_efrangi
Dear 's
i have a CMX virtual version 10.2.3 and Cisco WLC 5520 , i import the MAP and exported by using prime and i added the WLC and it give active
but now i am so confused cause i cannot find a helpful  document about this subject so my Question as below :
1) i used the location not presence so do i need to use prime or not and if i need is there any document for that
2)after i add the controller i cannot see any access point , do i need any configuration for that from the WLC side and CMX ? if yes is there any document
3) for client and Heat map the same i cannot see any thing ? is there any document for that
guys it's i am struggling here any helpful document will be nice
thanks
mohammed
5 Replies 5
You need Cisco PI to import maps to CMX location.
You need to synchronize controller information to CMX.
Refer below post as you may find some useful information
https://mrncciew.com/2016/06/10/cisco-cmx-10-2-part-2/
Rasika
***Pls rate all useful responses ***
HI Rasika;
thanks a lot your post really help me , but it's the same issue i cannot see any access point
do i need to add the access point to the PI and after that exporting the map
thanks
Assuming you have configured CMX and controller already
As far as I know
Prime is currently used only for maps.
so import map, size correctly, add APs to map and then export maps.
Import map to cmx and you will see clients in CMX.
[cmxadmin@CMX ~]$ cmxctl config maps import
you can choose to import a file or directly from PI
A
Hi Andrew
thanks for your answer i already exported the map's , but without using any AP ,i install PI just for that without any configuration or adding any access point
is it possible to work like that
thanks
Add controller to PI
Add map
Add APs and place APs to map
and then export
in CMX the APs will display numbers which indicates # of clients connected
A
