Compressing directory with archive tar command error
I need to backup an AP IOS to a TFTP server, I use the archive tar /create command according to the cisco documentation and I get an error
ap#archive tar /create tftp:192.168.1.186/c1200-k9w7-mx.122-11.JA3.tar  flash:/c1200-k9w7-mx.122-11.JA3
%Error opening  (No such device)
There is an sintax error?
5 Replies 5
Stephen Rodriguez
Yes you have a syntax error.  it should be tftp://192.168.1.186
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Hi Stephen
Same result
ap#archive tar /create tftp://192.168.1.186/c1200-k9w7-mx.122-11.JA3.tar  flash:/c1200-k9w7-mx.122-11.JA3
and
ap#archive tar /create tftp:/192.168.1.186/c1200-k9w7-mx.122-11.JA3.tar  flash:/c1200-k9w7-mx.122-11.JA3
the flash should just be flash: I believe
HTH,
Steve
HTH,
Steve
Same result
Hi Friends,
I need to copy several files and one folder, but they arent´compressed. I issued the create command, but it didn´t work. Cisco 2651XM - IOS Version 12.4(15)T14.
Any idea about it?
router#archive tar /create
% Invalid input detected at '^' marker.
router#archive tar ?
/table List files in tar file
/xtract Extract files in tar file
router#archive tar
