01-21-2016 12:02 PM - edited 07-05-2021 04:31 AM
We've recently rebuilt our wifi controllers using the standard anchor controller design. Foreign controller in our corporate network and guest controller anchored beyond our firewall in our wifi dmz.
Since the rebuild all our guest authentication requests to both ISE and an external radius server are occurring from the foreign controller not from the guest controller as pre-rebuild.
Its now driving us stir crazy trying to identify what we've missed in the configuration and would be grateful if someone could point us in the obvious direction I'm sure.
J
01-22-2016 02:15 PM
What was the idea with this migration? Just new hardware / software or also the change in the topology and/or configurations?
Within an anchored setup it is always the foreign WLC who is responsible for layer 2 authentication. Layer 3 authentication is being done on the anchor WLC. The catch is that with CWA (Central Web Authentication) ISE uses MAC authentication (layer 2) as a trick to be able to send CoA (Change of Authorization). Because of this the requests will come from the foreign controller in this case.
If you are still having questions, please share the current configuration of the WLAN on both controllers (show wlan x) so we can take a look at it.
Please rate useful posts... :-)
01-23-2016 04:07 AM
Thanks for the reply, we had a flash failure and took the opportunity to "clean" our configuration of a lot of obsolete code.
Odd thing is we have had to amend our firewall policies to permit auth requests from the foreign controller when it previously worked without. Also our ISE logs show previous requests from our anchor but since rebuild from the foreign.
We actually use Cisco "reciprocal wifi model" with a business partner (two separate companies broadcasting each others SSID and anchoring to the originators controller, we dont really want to be authenticating on their behalf also doesnt seem right our untrusted guests who can be public authenticating from our trusted controller.
Configs as follows
FOREIGN
(Cisco Controller) >show wlan 8
WLAN Identifier.................................. 8
Profile Name..................................... Shared Visitor web auth
Network Name (SSID).............................. Visitor
Status........................................... Enabled
MAC Filtering.................................... Enabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Disabled
Radius-NAC State............................... Enabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
ATF Policy....................................... 0
Number of Active Clients......................... 187
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 32400 seconds
User Idle Timeout................................ 7200 seconds
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... wifi-cont-1
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Enabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
PMIPv6 MAG Profile........................... Unconfigured
PMIPv6 Default Realm......................... Unconfigured
PMIPv6 NAI Type.............................. Hexadecimal
PMIPv6 MAG location.......................... WLC
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ 10.33.222.2 1812 *
Accounting.................................... 10.33.222.2 1813 *
Interim Update............................. Enabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Disabled
WAPI.......................................... Disabled
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Enabled
FlexConnect Local Switching................... Disabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional but inactive (WPA2 not configured)
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Not Applicable
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Mobility Anchor List
WLAN ID IP Address Status Priority
8 192.168.250.3 Up 3
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Local Policy
Priority Policy Name
ANCHOR
Profile Name..................................... Visitor
Number of Active Clients......................... 180
Exclusionlist.................................... Disabled
NAS-identifier................................... GUEST_WIFI
Interface........................................ visitor
Radius Servers
Accounting.................................... Disabled
Security
SIP CAC Fail Send-486-Busy Policy................ Disabled
DMS DB is empty
8 192.168.250.3 Up
Local Policy
All suggestions very much appreciated.
J
01-23-2016 08:10 AM
Your configuration works as expected and is correct for CWA. Because you have MAC filtering and radius NAC enabled on the foreign this controller will contact ISE. ISE uses the client MAC authentication phase to check if it is a known client. If ISE does not know about the client it should return an authentication profile which triggers the redirection so the client can authenticate itself.
My guess is that in the past you use LWA where you only had external webauth (layer 3) configuration on the anchor controller. Was this the case?
