PCF or just DCF in Cisco AP ?
mkoch
Level 4
Level 4
Hi !
I was reading the IEEE 802.11 spec and now i'm wondering if the Cisco APs do PCF (Point Co-ordination Function) or just use DCF (Distributed Co-ordination function)
I was unable to find anything in the Docs or on the AP interface...
Thanks for any input
Michael
jorge_lopez
Hello Michael. I have the same doubt as you. After searching in several sites I think I have one answer that may be right (but not sure :( ). You can set up a RTS packet size treshold. I thhink DCF is based on RTS/CTS, so PCF will be used when packets are smaller than the treshold, and DCF when are bigger. Using a tresshold of 2400 disables de DCF function. I'm not sure, so if anyone has more accurate information, please, tell us
bmcmurdo
PCF is not implemented on Cisco APs. PCF is not generally thought to be a very effective/useful QoS technique
The radio Access Point (and radio firmware) are "PCF aware" meaning if they
detect a PCF coordinator they will "play nice" in that area and back off a
little so it can do it's best effort.
IEEE 102.11e working group is currently working on a QoS standard but that has not yet been ratified.
