06-04-2008 09:33 AM - edited 07-03-2021 03:58 PM
Hi, I have received some new ap1231 with c1200-k9w7-mx.123-8jec IOS. I can't set anymore tx and rx antenna to Right(Primary) value. Do you know why?
Please take note that with the previous IOS was possible to do this.
Thanks a lot
Solved! Go to Solution.
06-04-2008 10:23 AM
Hi Roberto,
You are hitting this Bug;
These caveats are resolved in Cisco IOS Release 12.3(8)JEC1:
CSCsl17857
1231 access point running Cisco IOS Release 12.3(8)JEC is unable to set transmit/receive antenna options.
http://www.cisco.com/en/US/docs/wireless/access_point/ios/release/notes/12_3_8_JEC1rn.html#wp188929
Hope this helps!
Rob
06-04-2008 10:23 AM
Hi Roberto,
CSCsl17857
Hope this helps!
Rob
06-30-2008 06:02 AM
Rob, does this include the problem with configuring an external antenna.
With previous 1232 AP's I've not had any problems configuring a 9dBi Hawking antenna on this ap. Now when I enter the information and hit save, it takes me to a 404 page. I've attached a couple of pdf's and a txt file showing the results.
I hope this fix addresses my issue as well.
Thank,
Lonny LeGrand
07-01-2008 06:17 AM
Hi Lonny,
I don't think this bug is related to your issue as it is specific to the 1231. What exact IOS are you running so we can check this out.
Rob
07-10-2008 11:30 AM
FYI, I'm updating this to inform all that the software upgrade resolved my issue with configuring an external antenna as well as the TX and RX issue.
