Unable to join an AIR-CAP2702E-E-K9 to WLC5508
Ha Dao
Hi expert guys
I have new AP CAP2702E-E-K9 but can not join it the current WLC
After config IP, gateway and WLC address, it only show
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255) on the console screen
Help me to check it
AP002c.c8ea.308c#show capwap ip config
LWAPP Static IP Configuration
IP Address 107.107.70.5
IP netmask 255.255.255.0
Default Gateway 107.107.70.1
Primary Controller 107.107.211.4
AP002c.c8ea.308c#ping 107.107.211.4
Sending 5, 100-byte ICMP Echos to 107.107.211.4, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
6 Replies 6
Bill Klosa
On occasion we get an AP that will not join automatically. At that point I  use the following command on the AP in enable mode:
capwap ap controller ip address <ip address of controller>
Hi Bill, i also use that command: capwap ap controller ip address 107.107.211.4
Connect a console cable to the AP and reboot the AP.  I want to see the entire boot-up and the WLC discovery process.
Hi Leo
Help me to check the AP boot up process, thank you so much
which method are you using to discover WLC by AP ?
Check this:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/70333-lap-registration.html
Hmmmm ... Static IP address.
In enable mode, enter this command "capwap ap primary <WLC Name> <WLC Management IP address>".
