WLC 2504 Migration Path
Alejandro.Angon
I have a WLC 2504 and I need to upgrade it from 7.0.116.0  to 7.3.112.0 software version. I sow at the 7.1.91.0 release download page an advertisement that says "Migration path is from 7.1 to 7.2 Release" so I would like to know if I need to upgrade from 7.0 to 7.1 and after to 7.3 release code or if it´s posible to do it directly from 7.0 to 7.3
thanks a lot for your help
Leo Laohoo
Yes you can upgrade direct from 7.0.98.X.
11 Replies 11
Leo Laohoo
hi leolaohoo,
do you know any reference about this?, I need to be very sure of the procedure because the WLC service is critical
thanks a lot for your help.
Saurav Lodh
Level 7
Level 7
You can migrate that way. Please see the image
Alejandro.Angon
I have just upgraded the WLC directly form 7.0.116.0 to 7.3.112.0 without any problem. I have many  flexconnect APs and I didn´t lose any VLAN mapping as it would happend triying to upgrade to 7.4.100.0
http://www.cisco.com/en/US/partner/docs/wireless/controller/release/notes/crn7_3_112_0.html#wp1057104
best regards
can we limit bandwidth on wlc 2504.?
No you can not , on 5508 model you can.
Depending on what firmware you are using you can limit bandwidth in two ways:
1.  Limit bandwidth on SSID; or
2.  Limit bandwidth per user.
The WLC2504 does not support per-user or per-WLAN QoS. Only the 5508 and up support those features.
Dont forget to rate helpful posts
and what about per interface. bandwidth limit.?
Not supported on 2504 WLC.
Don't forget to rate helpful posts
