WLC User Login error
Ralf_Geronimo
%DOT1X-3-USER_LOGIN_DENY: 1x_auth_pae.c:2566 Authentication rejected for user ******** - user may already be logged in
%APF-1-USER_ADD_FAILED: apf_ms.c:5665 Unable to create username ******** for mobile
WLC Version: 7.0.220.0
intermittent problem
Help me please!
11 Replies 11
Justin Kurynny
Level 4
Level 4
Ralf,
How many concurrent logins do you allow on your controller? Security tab --> User Login Policies
Justin
jasonrakers
I am having this same problem, if anyone has any suggestions.  concurrent logins is set to 0.
Are you using radius? If so, check the radius configuration. Some have the ability to also set the max login.
-Scott
I'm having the same issue as well.. Any advise?
If your issues is with multiple logins, make sure your allowing that on the WLC. If you look at the image I posted, I'm limiting multiple logins with the same username to '2'. You can set this from 1-8 or else '0' is unlimited.
-Scott
Are you using a radius server and AD ? Did u configure user-dialin- properties to allow the groups ?
Sam
Let me check with our client first and revert back once we received the feedback from them... FYI, this issue had been resolved after rebooted the WLC.. Currently, everything is working fine and we wish to find a root caused, if possible.
Well after a reboot, I don't think you will be able to find the root cause until it happens again. Maybe your radius connection to the WLC failed.
-Scott
Im also facing the same Issue right now.. I haven't rebooted the controller, My primary controller is deactivated from the global list and seconday controller is running. But i could able to reach my primary controller(pinged from controller-radius
server (which is over WAN connections, not local i.e differrent geograhical area)
*Dot1x_NW_MsgTask_2: Mar 22 13:23:31.372: %DOT1X-3-MAX_EAP_RETRIES: 1x_auth_pae.c:3028 Max EAP identity request retries (3) exceeded for client 30:f7:c5:c4:43:6a
*Dot1x_NW_MsgTask_2: Mar 22 13:23:31.372: %DOT1X-3-USER_LOGIN_DENY: 1x_auth_pae.c:2566 Authentication rejected for user 00005115 - user may already be logged in
concurrent logins is set to 0 (unlimited logins). what would be the reason behind this? Same issue we faced 2 months ago then we have rebooted the WLC and it worked Fine.
Again now we are facong the same issue. Reboot won't be permanent resolution to this, Please can you let me know the root cause.
Thank you in advance..
I don't know the root cause, but I know upgrading the WLC to newer code fixed the problem for me.  We are now at 7.0.235.3 without incidents.
you could be hitting a bug on that code.
what code are you running, let me try bug scrub.
Ralf Geronimo - 7.0.220.0
chanseeyee - ?
kiran kumar - ?
