08-06-2014 01:18 PM
Hi folks,
I have another odd problem while using the bulk firmware feature in VSM 7.2.0.
When using the firmware upgrade utility within VSM, once the cameras successfully upgrade, they are moved out of their child location to the root location of the tree. Is this just a bug or could it mean something bigger.
We are about to upgrade to 7.5 and if its just a bug I'll just deal with it.
-Nick
08-07-2014 07:01 AM
I can't seem to find anything in the release note caveats, but what you are saying really rings a bell. If you test/investigate after the upgrade, I'd love to hear about it.
Cheers,
Scott
08-07-2014 07:04 AM
Scott, I certainly will. I just opened a TAC case concerning this to make sure the DB and such is not out of line. We plan on upgrading to 7.5 within a week and want to make sure everything is solid before so.
Ill keep this updated.
08-07-2014 07:22 AM
FYI - there's a 7.5.1 available now as well... you may want to jump straight to it.
08-18-2014 11:14 AM
how many of us have jumped to 7.5.1?
I've just upgraded our entire stash to 7.5
08-20-2014 11:24 AM
I'm on 7.5.1 currently with no hiccups at all. About to test the firmware issue. Will report back with results.
08-21-2014 08:15 AM
sounds good.
08-21-2014 11:18 AM
I just got finished testing the upgrade process again on 7.5.1 and it appears that the issue has been resolved. The cameras do not move after being upgraded. One thing I did notice, maybe it's just me, is that when you try to expand a column to see the extended information on rows it does not work. We have some long location names and I am not able to expand out to see the entire path. Not really a big deal but thought I'd throw that in there.
08-18-2014 06:08 PM
Hello Nick
Seems like you are hitting this BUG and fixed in 7.5(1) which is a latest release or open a TAC case for intermediate fix
CSCuo20267
Camera installation positions change upon Media Server services restart
CSCuo20267
Description
Symptom:
Cameras that were moved from one Media Server to another under the same VSOM, will occasionally encounter a "jump" of their install location to the root of the Install tree for the device.
Conditions:
Changing the Cameras and/or Encoders from being managed/configured on one Media Server to another Media Server, under the same VSOM.
Workaround:
Manual removal of the device from the prior Media Server.
