Cpam- Door State Inconsistent
philtraylor
Anyone know why on earth I would get this error?
I have a couple doors showing alarms for  "Door State Inconsistent"
I can not seem to figure out why. All the devices associated to the door are functioning properly...
Thanks!
Phil
7 Replies 7
mcwalter
Level 3
Level 3
Which input triggering the door state inconsistent event?
I can not tell. Further examination of the alarm does not seem to specify which input point is causing the issue.
What am I missing?
You may want to run a system sanity report. It may tell you where the error is. Good luck.
Good call. I will check there. Thank you!
I have the same issue at the minute. Have you had any further help on this?
Kind regards,
Finbarr
I have not gotten much luck in this area, I ended up disabling this alarm entirely.
wsmith3212
Generally I have found that a motion REX that is incorrectly configured to trip the lock in a high traffic area can pop the lock when the door isnt being used causing that alarm.
