ā11-03-2011 02:02 PM
Anyone know why on earth I would get this error?
I have a couple doors showing alarms for "Door State Inconsistent"
I can not seem to figure out why. All the devices associated to the door are functioning properly...
Thanks!
Phil
ā11-04-2011 11:36 AM
Which input triggering the door state inconsistent event?
ā11-04-2011 11:38 AM
I can not tell. Further examination of the alarm does not seem to specify which input point is causing the issue.
What am I missing?
ā11-04-2011 11:58 AM
You may want to run a system sanity report. It may tell you where the error is. Good luck.
ā11-04-2011 11:59 AM
Good call. I will check there. Thank you!
ā08-02-2012 03:46 AM
I have the same issue at the minute. Have you had any further help on this?
Kind regards,
Finbarr
ā08-02-2012 06:06 AM
I have not gotten much luck in this area, I ended up disabling this alarm entirely.
ā08-29-2012 05:56 PM
Generally I have found that a motion REX that is incorrectly configured to trip the lock in a high traffic area can pop the lock when the door isnt being used causing that alarm.
