management software for CIVS -IPC-6930
MMoharam1
  • Is there management software included in the package  for CIVS-IPC-6930  ?
  • OR We have to buy a management software
5 Replies 5
Nadeem Ahmed
Hello ,
Management software in terms of what exactly you are looking ? Firmware packages.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
hi nadeem
not firmware  bit GUI software that control and manage the ip camera
I would highly recommend you engage your local Cisco representative to better gauge what your needs are.  Ideally, you are looking for the following software suite from Cisco:
http://www.cisco.com/c/en/us/products/physical-security/video-surveillance-manager/index.html
Cheers!
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
Are you talking about the software that helps you to set up the camera? (IP Addresss and others)
Hello Moharam,
As what i understand from your query that you are looking for the camera controls, motion detection and Pan, tilt & zoom controls on this camera.
So all this option will come automatically once you login the camera from IE browser and turn-off the pop-up blocker. Go to "View Video" tab then the "Cisco Camera UI control" plug-in automatically pop-up on browser,click on accept and install on the system and you can control the camera properly.
Hope this help you.
Warm Regards,
Jayesh
