REMOTE STORAGE ON FMC
fmugambi
Hello Team,
Getting attached error while I try to configure Remote Storage  on FMC for backups.
Am using windows server NFS for this.
Kindly assist.
15 Replies 15
Torbjørn
Connection timed out seems to indicate that your FMC isn't able to reach the server. Can you ssh to your FMC, enter shell with "expert" and check that you can reach your NFS server by running "telnet (nfs server IP) 2049"?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Can I see how you config server via FMC
MHM
Please check out this guide, it might be of help:
Install NFS Server & Create NFS Share in Windows Server (operavps.com)
getting these errors, once is capture, then other is the actual error.
Please help assist identify what I would be missing.
NB:// am able to reach fmc from the nfs server.
You dont share how you config it'
Share step and screenshots'
MHM
fmugambi
the host and/or directory is wrong
MHM
balaji.bandi
Adding to other posts.
1. basic testing,FMC reachable to NFS Server ?
2. check on the NFS server any errors ?
. Looks for me reachability and permission issue
BB
fmugambi
Hello team, this worked, seemed to be an access issue.
But still not working how i intended.
Have don scheduling for the fmc and the managed device. for the managed device i did not check the 'retrieve to fmc'. so whats happening is on remote storage i have only backup for the fmc, not able to see the ftd.
Did I miss something?
have you created FTD backup profile ?
you need to setup FTD backup also.
BB
fmugambi
yes i have
wait, actually the jobs are successful,
but on remote storage where do i get FTD backup files, currently just seing fmc backup file.
sf-storage\xxxxxxxxxxxxxx\backups
you see both FMC and FTD backups.
BB
for the FTD i dont need to have 'retrieve to fmc' checked correct?
Am still able just to see the FMC backup alone ...
