C892FSP-K9 configuration
diegog
Hello everyone,
I'm having some issues with my router.  I'm trying to connect it to the internet, I can ping to google.com but on the other hand, when I connect a machine in interface G1, I don't have internet connectivity, I think the problem is in interface g1. I don't understand this router, it has 2 wan ports and 8 L2 ports.
My configuration is below.
Wan Interface G9
Public IP 24.XX.XXX.106
Route 24.XX.XXX.105
DHCP Server 192.168.1.115
R1(config)# interface g9
R1(config-if)# ip address 24.XX.XXX.106 255.255.255.252
R1(config-if)# ip nat outside
R1(config-if)# no shut
R1(config-if)# ip route 0.0.0.0 0.0.0.0 24.XX.XXX.105
R1(config)# interface vlan 1
R1(config-if)# ip address 192.168.1.1 255.255.255.0
R1(config-if)# ip nat inside
R1(config)# interface g1
R1(config-if)# switchport mode access
R1(config-if)# switchport access vlan1
R1(config)# access-list 10 permit 192.168.0.0 0.0.0.255
R1(config)# access-list 10 permit 10.0.0.0 0.0.0.255
R1(config)# ip nat inside source list 10 interface g1 overload
R1(config)# interface vlan1
R1(config-if)# ip helper-address 192.168.1.115
7 Replies 7
Mark Malone
Hey
hmm why is the NAT set to to G1 , that should be pointing to the G9 as that's the WAN interface
change to
R1(config)# ip nat inside source list 10 interface g9 overload
Hi Mark,
You are absolutely right, I'll try that tomorrow morning and I'll let you know if it works.
Hi Mark,
Do you think vlan1 and g1 are configured in the correct way?
Yes but you shouldn't have to specify access vlan 1 as the port as all layer 2 ports by default are assigned to vlan 1 unless changed
where is your dhcp server is it on 192.168.1.x/24 if it is then the vlan does not require a helper address this is only so packets can switch from broadcast dhcp to unicast dhcp to find a dhcp server in another subnet
your acl is wrong too its /24 subnet in vlan 1 192.168.1.x/24 , your acl is 192.168.0.x for NAT
so in short this below should do it , nat inside on vlan , nat outside on wan , point overload to wan interface and allow vlan subnet to be natted to get to outside public networks
Let me know how that goes
R1(config)# access-list 10 permit 192.168.1.0 0.0.0.255
Mark,
I'm gonna try this next Saturday because I can't stop internet know but for sure I'll let you know how it goes.
Thank you very much again.
no problem good luck with it
Hi Mark,
once again, you were right, it is working!.
Just to remember, I have some ports to forward
ip nat inside source static tcp 192.168.1.x 1190 interface g9  1190
ip nat inside source static udp 192.168.1.x 1190 interface g9  1190
Do you think we need ACL as well?
access-list 11 permit tcp any any range 0 65535
access-list 11 permit udp any any range 0 65535
Thank you, I appreciate a lot your help
