Cannot access Web Gui Interface on RV345
lloving
I Cannot access Web Gui Interface on RV345. The GUI login page appears but after entering known correct credentials GUI does not progress. GUI appears to hang at that point with dancing ants cursor. See attached screenshot.
Also: SSH access via port 22 fails to connect.
do you have backup of this config, if so reset to factory and apply the config from backup.
BB
9 Replies 9
balaji.bandi
I can't see what firmware version is running on this router since I cannot access either the GUI or the CLI.
have you tried any other browser like IE/ FF ?
BB
IE yields the same results. Going on site to do a reboot.
Reboot did not resolve the issue.
BB
lloving
I was hoping to avoid truck rolls to reset these 3 units. Thanks for the help.
CoreyP319
Hi Lloving,
Depending on the firmware version you may be encountering:
RV340 Series Small Business routers (PSIRT Notice)  Fix for CSCwc53007- RV34x GUI not accessible –  The recommended fix is to upgrade to firmware version 1.0.03.29
lloving
Will do when next on site with the offending units.
