ā10-26-2021 06:55 AM
Hello every one, I have a Cisco Router 2600 Series and I would like to reset it to the config factory. IĀ“m using Putty to perform the reset but I turned ON the router and send CTRL/Break from the keyboard, it doesnĀ“t allow me to access the romon mode. Even by selecting the special command Break from Putty I have no success.
Is there another way to reset the router to the config factory, other than this?
Solved! Go to Solution.
ā10-26-2021 12:31 PM
did you follow the steps still not work? are you able to get into ROMMON ?
connect console capture all the logs and posts them here.
ā10-26-2021 06:57 AM
you can login to router and use below commands to clear existing configurations and reload without saving.
#erase startup
#delete vlan.dat
rate this and mark as answer, if this resolved your concern
ā10-26-2021 08:45 AM
Hi Kasun,
I forgot the password. This is why I want to reset it.
ā10-26-2021 07:07 AM
Do you have access to device and able to login or you lost login details ?
is this new 2600 or old
try below link :
https://www.hardreset99.com/routers/cisco/cisco-2600-factory-reset/
ā10-26-2021 08:47 AM
Hi Balaji,
Unfortunately I donĀ“t have the password. I forgot !
Its an old model
ā10-26-2021 08:49 AM
Hi Balaji,
Unfortunately I donĀ“t have the password. I forgot the password!
Its an old model
ā10-26-2021 10:23 AM
I do have access to the route by asking to enter the password, but I donĀ“t remember it.
ā10-26-2021 10:36 AM
I already followed these steps with no success:
ā10-26-2021 01:20 PM
Still did not work. I was not able to get into ROMMON mode. This is what I get by pressing CTRL/BREAK or special command via Putty:
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0xd76044
Self decompressing the image : ############################################################################################################################################################################################################################ [OK]
Smart Init is disabled. IOMEM set to: 10
Using iomem percentage: 10
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(11)T6, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 14-Feb-03 05:22 by ccai
Image text-base: 0x8000809C, data-base: 0x81673EB0
cisco 2611 (MPC860) processor (revision 0x203) with 59392K/6144K bytes of memory.
Processor board ID JAD05030COV (472729635)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 Ethernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
station-id number 551155059494
Press RETURN to get started!
*Mar 1 00:00:09.178: %PA-2-UNDEFPA: Undefined Port Adaptor type 65535 in bay 1
*Mar 1 00:00:13.313: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Mar 1 00:00:13.313: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
*Mar 1 00:00:13.313: %LINK-3-UPDOWN: Interface Serial0/0, changed state to down
*Mar 1 00:00:13.317: %LINK-3-UPDOWN: Interface Serial0/1, changed state to down
ā10-26-2021 01:26 PM
Try different terminals here some break commands and procedures: ( get Secure CRT) - what is the version of putty? what kind of cable ?
https://www.cisco.com/c/en/us/support/docs/routers/10000-series-routers/12818-61.html
putty serial config
ā10-26-2021 01:37 PM
IĀ“m using Putty Release 0.76. Also I tried TeraTerm, latest version with no success.
IĀ“m using a USB to Serial cable converter and a Console cable connectec do the Console port.
If I set the Row Control do None, nothing happen. ItĀ“s like there is no communication with the router.
ā10-27-2021 12:17 AM
if you have any other device, test the Console cable working as expected ? the procedure same we use all time.
At this stage, either i suspect console cable ? some reference for success.
https://community.cisco.com/t5/other-security-subjects/2821-password-recovery-disabled/td-p/2098014
ā10-27-2021 12:06 PM
I have another device, a Cisco 2500 series, I was able to connect to it.
But I will get another console cable to test.
Thanks in advance for your attention
