Good morning
Thanks for using our forum
Hi Danny Herremans my name is Johnnatan and I am part of the Small business Support community. In order to solve your problem follow these steps.
1. Go Firewall>General>Disable “Block WAN Request”
2. Go Firewall>General>Enable ”Remote Management”
3. Go VPN>VPN Pass Through>Verify all option be “enable”
4. In your internal network 1 try using a different address instead of 192.9.212.1 use a private network, in the range 192.168.x.x.
5. Create these two firewall rules in your computer
http://www6.nohold.net/CiscoSB/Loginr.aspx?login=1&pid=4&app=search&vw=1&articleid=2922
I hope you find this answer useful, if it was satisfactory for you, please mark the question as Answered.
Please rate post you consider useful.
Greetings,
Johnnatan Rodriguez Miranda.
Cisco network support engineer
“Please rate useful posts so other users can benefit from it”
Greetings,
Cisco Network Support Engineer.
