Cisco RV340 - Static routing configuration procedure
RomanBuk1511
Someone can decribe me the all steps i should preform in order to excute ping between to networks.
-WAN settings
-Routing configuration
-PC NIC Configuration
The setup is: PC 1>WAN1 port, PC 2>WAN2 Port.
Thanks.
balaji.bandi
below guide give you basic settings :
https://notesfrommwhite.net/2015/04/23/install-and-configure-of-the-cisco-rv325-firewall/
Once you done that you can do same for other PC2 VLAN IP address.
BB
Thanks.
But the implamentation should be via L3, i.e. static routing, WAN configuration etc, not by vlans etc.
