Fail to upgrade SRP 521W
abrasini
I'm trying to upgrade a SRP 521W.
Current release:
Hardware Version: V01
Boot Version: 1.1.11 (Aug 21 2009 - 20:14:07)
Every time i start the process (tried different releases available on CCO) at 4% I get the error:
"Upgrade is failed"
Any help for me ?
Thanks Alessandro
7 Replies 7
Andrew Hickman
Hey Alessandro,
Try a factory reset of the SRP before upgrading again.
Mail me directly if you still have problems.
Cheers
Andy
I am having the same problem and i have completed a factory reset and tried again. still not working beond 4%
Do you have tried the upgrade procedure via web menu?
Can you change the internet browser?
A second way to upgrade the device is to use the provisioning upgrade procedure. You must have a web or tftp server and use this url:
http://YOUR_SRP_IP_ADDRESS/admin/upgrade?tftp://YOUR_TFTP_SERVER/FIRMWARE_FILE
or
http://YOUR_SRP_IP_ADDRESS/admin/upgrade?http://YOUR_HTTP_SERVER/FIRMWARE_FILE
Regards.
I have used firefox, Crome and Safari.
thanks
Reply-To: "cisco-support@sgaur.hosted.jivesoftware.com" >
Date: Sun, 22 Apr 2012 04:43:46 -0600
To: Angus Parker >
Subject: - Re: Fail to upgrade SRP 521W
Home<>
created by Daniele Giordano<> in Small Business Routers - View the full discussion<>
Andrew Hickman
Which release are you attempting to upgrade to?
1.1.26. I am on 1.1.11 and i have tried doing an order from
1.1.19
1.1.24
1.1.26
Still not working
Thank you
Angus Parker
Hi Angus,
Do you have access to a Syslog server? It would be useful to see what logging messages are generated when this happens.  To configure, go to the Voice > System tab and select 3+Router from the dropdown list.  Then add the IP address of your Syslog server to the address fields.
Andy
