07-19-2021 10:30 PM
I have a RV325 dual WAN unit which is working fine. I recently built a test webserver on one of my Raspberry Pi computers which in using 10.0.1.92. I can access that web server from my laptop on the RV325 network by going to that address so I know it is working.
The router has two WAN sources: WAN1 is a 4g modem/router and WAN2 is an ADSL modem/router. I have other ports open for access, for example Remote DeskTop, which are working. Below is a section of the firewall rules:
Not sure what I'm doing wrong or what I did differently for the Remote Desktop rule? That rule works fine when I access WAN2 with the external address for the ADSL modem/router. The Cisco WAN2 address is the DMZ address for the ADSL.
Can anyone offer some help or ideas? Thanks RDKCisco1
Solved! Go to Solution.
07-20-2021 04:31 AM
Thanks for your reply. I had checked the logs and there was never any reference to that port or rule. However, it has been a long time since I configured this RV325 router and I had forgotten that I had to configure a forwarding rule as well as the firewall access rule. When I added that it now works as expected.
Just another "user error"....RDK
07-19-2021 11:49 PM
- Check logs , for intended connection , lookup possible failure reasons for those not working.
M.
07-20-2021 04:31 AM
