08-07-2022 12:19 PM
Hello, I just bought a CISCO 888 router and I am trying to configure it for a very first time. The problem is that I need the L3 port for NAT but the router shows me only the L2 ports (0-3).
08-08-2022 06:20 AM
I tried this but still nothing. After 3th command shows me wrong command message so I checked with "?" and there are no commands like that.
08-08-2022 07:23 AM
Can you post below :
show version
show run
Also what you trying to configure ? VDSL or Ethernet delivery ?
08-08-2022 10:32 AM
I want to use this router as my main router but I staked in the very beginning. Can set a L3 port to take an IP from my ISP.
08-08-2022 11:01 AM
08-08-2022 10:55 PM
we understand this, but what kind of ISP delivery, is this Ethernet or VDSL.
i would advise reading the product documentation - the Router has 1 DSL controller and 4 FastEthernet. (if you are not able to configure any FastEthernet as a layer 3 interface, then that is is Limitation of the kit. it can only be used for DSL.
08-08-2022 11:46 AM
https://www.cisco.com/c/en/us/tech/dial-access/integrated-services-digital-networks-isdn-channel-associated-signaling-cas/tech-configuration-examples-list.html
this link provide you all necessary config for BRI interface.
BRI interface config as PPP, you can config direct or you can config dialer interface depend on BRI as physical Interface.
