RV042G - Port Forwarding
dannroovaa
Hello Cisco Suppor Team,
I have been trying to configure Port Forwarding in RV042G but I have not success, I need to access from outside of my LAN to one server (Windows Remote Desktop), previously I have a Linksys E2500 were I configured as Image: ''port fw'' IP 192.168.1.54 for remote desktop using external port 4545 and internal port 3389, so when I change this router to my  RV042G I didn't find the external port config., if this is configurable can anybody tell me how?,
In second term, I enable 192.168.1.54 to be DMZ Host so we can access temporarily from the outside, but now I can't delete it, is there a kind of bug in this section or am I missing something?
Hope someone can clarify this,
Adrian
Michael Swenson
Yes the port translation is kind of hidden.  You need to use the Upnp
Setup - Upnp
Add a service and you will be able to assign a external port and then then internal port.  Apply this service to a Upnp rule to the IP address of the inside server.
Also, by default the DMZ host setting is 192.168.1.0.   Just set this IP in the DMZ and it will remove the server IP
Best Regards,
Mike
Michael Swenson
Setup - Upnp
Best Regards,
Mike
Hello Mike,
Many thanks for your feedback, now I can Forward all my services!
Also I have set 192.168.1.0 as default DMZ host,
Kindly Regards!,
Adrian
