RV260: VPN PPTP problem - user authentication
I bought a RV260 for VPN connections recently, firmware 1.0.00.17, and I try to config VPN PPTP since 3 days, as I often did it before. Even the easiest way to connect with VPN PPTP is not possible, because of the following error.
2020-Mar-24, 16:55:32 AZOTerrorvpnpptp: RADIUS: Can't read config file /etc/radiusclient/radiusclient.conf
2020-Mar-24, 16:55:32 AZOTerrorvpnpptp: rc_read_config: can't open /etc/radiusclient/radiusclient.conf: No such file or directory
I have no RADIUS configured (NO Remote Authentication Service)!
The problem seams to be well known with other routers, however unsolved!
Other VPNs e.g. IKE2 does not work either.
Does anyone know a solution for this problem?
Thanks for any help!
Serial NumberDNI2314A22H
System Up Time0 days 4 hours 14 minutes 55 sec
Current Time2020-Mar-24, 17:05:21 CET
PID VIDRV260-K9 V01
Firmware Version1.0.00.17
Firmware MD5 Checksum7e7f47aca77c363a0b440ff3ffe5f6ae
LocaleEnglish
Language Version1.0.0.0
Language MD5 Checksumd901cc97ae6a606564195bb34fc2d4d2
balaji.bandi
i see some issues around same-  replied to the user with information, but user never come back it was fixed or not.
https://community.cisco.com/t5/small-business-routers/rv260-and-pptp-fails/m-p/4034016
BB
Thanks for your reply, but I red this posts already and they do not have a solution.
PAP (without encryption!) does not work either, that's the log:
2020-Mar-24, 19:44:40 AZOTnoticevpnpptp: Connection terminated.
2020-Mar-24, 19:44:40 AZOTwarningvpnpptp: peer refused to authenticate: terminating link
2020-Mar-24, 19:44:40 AZOTerrorvpnpptpd: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Besides VPN without encrypted seems to defeat the purpose.
I tried it with different Windows systems, as well as with ubuntu. It seems to be a severe bug of quite a lot of this small business products.
I only bought this RV260 for VPN and now I can only use it as a firewall and switch. I probably will send it back soon.
However I still hope, that there is a solution.
PAP works as per below link. Disable MPPE encryption on router, PPTP server as well.
https://community.cisco.com/t5/small-business-support-documents/pptp-vpn-configuration-on-rv340-345-routers/ta-p/3220097
