RV345 inter VLAN routing not working
support.rabat
I have an RV345, which I am trying to configure to have 2 vlans and that all the equipment connected to vlan1 and vlan 2 can communicate with each other.
what I did as a configuration:
Vlan1: 192.168.1.1/24 (with DHCP server)
Vlan2: 192.168.2.1/24 (without DHCP server)
Both VLAN's have inter VLAN routing enabled
I connected a computer (IP in DHCP) to port 1, which I set untagged for Vlan1 and tagged for Vlan2.
the second computer (static IP 192.168.2.2) on port 2 that I configured as untagged for vlan2 and tagged for vlan1.
but the ping is failed between computer 1 and computer 2.
Do I miss something please?
2 Accepted Solutions
balaji.bandi
from the device are you able to ping the gateway? example :
192.168.2.2 should be able to ping 192.168.2.1
192.168.1.2 should be able to ping 192.168.1.1
if this is working, check the PC running windows has to built-in FW which may deny, so disable FW and test.
BB
Hope it was resolved, so can we mark as resolve this please..so useful for other members.
BB
balaji.bandi
BB
Thank you so much :)
it was FW on my pcs
BB
