RVO42 GATEWAY TO GATEWAY VPN IS NOT CONNECTING
ajay1komban
Dear all,
   When I try to create vpn connectivity between two RV042  routers, It showing waiting for connection
I am using DDNS in both gateways.
Firmware versions are different
1.
Serial Number : NKS17350412Firmware Version : v4.2.2.08 (Apr 26 2013 19:12:26)
PID VID : RV042 V03Firmware MD5 Checksum : 9f4450cc2cc023dc0e9d6aef842afd48
LAN
WAN1WAN2
IP Address : 217.165.146.236IP Address : 0.0.0.0
Default Gateway : 217.165.146.1Default Gateway : 0.0.0.0
DNS : 213.42.20.20DNS : 0.0.0.0
Dynamic DNS : Dyndns Enabled : Dynamic DNS is updated successfully.
AUHDUBAIwaiting for connectionDES/MD5/1192.168.10.0
255.255.255.0
192.168.1.0
255.255.255.0
tedfor
0.0.0.0
N/A
2.
Serial Number :    NKS10202121 Firmware version :    1.3.12.19-tm (Feb 13 2009 13:03:21)
CPU :    Intel IXP425-266 DRAM :    32M Flash :    8M
System up time :    0 Days 11 Hours 12 Minutes 24 Seconds    (Now: Thu Jan 8 2015 07:13:53 )
is it a issue of a  firmware different ?
Thanks & regards
Ajay Jose K
9 Replies 9
Jerry Paul
Properly check AES and SSH
Dear mdobiac & Jerry Paul
           Thank you for your support.
            I am using different versions in both side, is it a problem ?
Thanks & Regards
Ajay Jose K
Hello Ajay,
If by versions you mean hardware versions it should not have an effect on trying to establish a IPsec tunnel.
Michael D.
Dear all,
 In this both routers PPTP server mode (client based vpn is working fine)
firmware version is not same.
Ajay Jose K
Hello ajay1komban,
If it is the same hardware version then I would recommend having both units on the same firmware.
Further have you attempted my above suggestions?
Michael D.
Dear all,
It is working, If I change from DDNS mode  to IP .
It is not working in DDNS Mode.
is It possible in DDNS mode
Ajay Jose K
In DDNS mode is possible as long as you configure both routers correctly. This means on both devices you configure:
Local Security Gateway type: IP only
Remote security Gateway type: IP only
and the submenu: Resolved by dns
Kremena
mdobiac
Level 3
Level 3
Hello ajay1komban,
First double check your configuration on both sides of the tunnel and make sure everything matches.
You then could try checking to make sure your DDNS is resolving to your WAN IP addresses.
Lastly what I have noticed for initial site to site tunnel configurations if it doesn't connect right away or after you press connect you could try a power cycle on both routers to see if the tunnel will establish itself.
Thank you,
Kremena Ivanova
Can you share the VPN configuration options - In particular Local Security Gateway type and Remote security Gateway type. which settings have you selected on both routers
Kremena
