Hello!
I'm about to upgrading our RV042 to RV042G since everything in the Network ist ready for Gigabit except the RV042
I think it's important to mention that another RV042, which is at a 2nd location, will remain for the VPN connection between the two locations. (Older Hardware are used at the 2nd location).
My Question is, are there any known issues, which should be cleared before changing the router.
Mainly issues with configuration migration and compatibility between RV042 and RV042G VPN connections.
Thank you!
