0 bits/sec output rate
snarayanaraju
Level 4
Level 4
I am seeing 0 bits/sec output rate whereas the around 26Mbps traffic ingress to the interface.
What does it indicate? How the return traffic is not showing as output packets?
5 minute input rate 26319000 bits/sec, 3017 packets/sec
regards,
SAIRAM
8 Replies 8
Pawan Raut
Level 4
Level 4
it may possible outgoing traffic on another device/ interface.
Thank you. That makes sense. It is possible in my setup
Any other thought or chances for this situation? thanks
I remember there to be a bug in older IOS versions, which one are you running ?
Also, the outgoing traffic rate might be too low to show up in the interface statistics. Try to change the load interval on the interface to 30 and see if that makes a difference:
Router#conf t
Router(config)#int serial0
Router(config-if)#load-interval 30
Cisco ASR Version 15.1(1)S: asr1001-universal.03.02.00.S.151-1.S.bin
Can you post the full output of 'show int' ?
edgertr02#show int gig 0/0/2
GigabitEthernet0/0/2 is up, line protocol is up
Hardware is ASR1001, address is 0009.7d34.d104 (bia 0009.7d34.d104)
Description: Internet
Internet address is x.y.x.x/30
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 6/255
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is T
output flow-control is on, input flow-control is on
Last input 02:15:13, output 02:15:13, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 26130000 bits/sec, 3163 packets/sec
15617780531 packets input, 17231110867535 bytes, 0 no buffer
Received 5151 broadcasts (0 IP multicasts)
0 watchdog, 2 multicast, 0 pause input
51845891 packets output, 28726310589 bytes, 0 underruns
0 output errors, 0 collisions, 11 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
your input packets (15617780531) exceed the output packets (51845891) by a factor of 300. So there definitely is output traffic, but likely too little to show up in the interface stats. Have you tried yet to set the interface load-interval to 30?
Looks like the output rate is very low. Even changing the load interval to 30 sec doesnt reflect in "show interface counters". As you noticed there is output packets but it increases at the rate of 1 packet
