10GE SPAs, whats the difference between these 2?
Jack Leung
SPA-1X10GE-WL-V2
and
SPA-1X10GE-L-V2
I'm looking to add ASR 1002s for my internet edge and I need 10GE interfaces on them. Is there a difference between those 2 I've listed?
LW stands for LAN/WAN. L is only LAN. The LW have WAN SONET capabilities, so if you are going to connect this to a 10G Ethernet switch, this are useless, buy only the LAN version.
  Br
  Alex.
From the datasheets, both support SONET
Both document contain : "
The Cisco SPA/SIP portfolio allows deployment of different interfaces (packet over SONET/SDH [POS], ATM, Ethernet, etc.)"
Only difference with WL is "
• WAN, SONET/SDH, dense wavelength division multiplexer (DWDM), and add/drop multiplexer (ADM) connectivity (WAN PHY mode)"
What if I need to configure OTV in ASR 1002 connecting it to Brocade Switch, will SPA-1X10GE-L-V2 be enough in this case?
Thank You.
Ahmed.
Hi Ahmed,
Sorry i know its an old query but just im curious to know if you try to connect SPA-1x10GB-L-V2 with OTV. DCI it looks extend the LAN which i think it should be ok. Could you share your experience.
Saeed
