04-19-2020 07:39 AM
So I' having the WAN connection between ASR's in different physical data centers running OSPF , Each WAN data center are having the below config and differ in terms of LSA and SPF timers , will there be any effect on the long run knowing that both are falling under one area ( area 0 ) .
Data Center 1 WAN Config :
router ospf 1
timers throttle spf 2000 8000 8000
Data Center 2 WAN Config :
router ospf 1
timers throttle spf 50 200 5000
timers throttle lsa 50 200 5000
04-19-2020 02:06 PM
Hello
TBH these SPF timers are dynamically set by ospf and my understanding is you only would need to tweak these timers if you wish to speed up network convergence times through SPF calculation, Which could have the affect of an unstable network is set incorrectly, So I would say at the very least these timers should have parity on each opsf router within your network.
04-20-2020 04:38 AM
04-19-2020 09:41 PM
Its always recommended to use the standard SFP calculation value as if you change it it is going to impact all the devices.
