Subnetting question
The_guroo_2
Level 2
Level 2
Guys can some one explain to me the follwoing
if we have 192.168.1.0/24 address
and we want t furthur subnet that in to /28 (how many addreses we will get)
what is the way to do it and how does the calcultion work number of subnets etc
I cant get my head around
Thanks heaps
5 Replies 5
fgasimzade
Level 4
Level 4
Here is a good subnet calculator for you
http://www.subnet-calculator.com/
If you make it /28 or 255.255.255.240, it means you will get 16 addresses. First address will be your network address, last address - broadcast address. After all, you will get 14 hosts per subnet, and 16 subnets overall
cadet alain
there are 2 ways to do the math:
the long way which is in binary or the short way which is in decimal
192.168.1.0/24 is your network address and that means you have 24 network bits(first 3 octets) and 8 host bits(the last octet).
You want a /28 so you are subnetting so borrowing bits from host part to make them subnet part
How many? 4 because 28-24=4 so how many subnets is this? 2 to the power of 4= 16 subnets
How many hosts in each subnet? (2 to the power of 4 ) minus 2 for broadcast and subnet address= 14
where did this 4 come from : 32-28=4
the binary way:
Now you're gonna have something like this: NNNNNNNN.NNNNNNNN.NNNNNNNN.SSSSHHHH
let's take last octet:
00000000 first subnet  192.168.1.0
00000001 first address in this subnet 192.168.1.1
00001111 broadcast 192.168.1.15
00001110 last address 192.168.1.14
0001000 2nd subnet 192.168.1.16
00010001 first address in this subnet 192.168.1.17
00011111 broadcast 192.168.1.31
00011110 last address in this subnet 192.168.1.30
Or the decimal way
a /28 is 255.255.255.240 so 256-240= 16 is the subnet increment  so
1st subnet 192.168.1.0/28
2nd subnet 192.168.1.16/28
and so on and in first subnet: 192.168.1.1 is first address, 192.168.1.15 is broadcast( next subnet-1) and 192.168.1.14 is last address( broadcast -1)
Regards.
Alain.
Hi Frnd,
Your question is quite easy..You have questioned abt the supernetting where we do subnetting of the subnets.
Alain shown you a proper solution in all ways.
And for more detailed knowledge you can refer the attached document.
Amit
Sakun Sharma
See subnetting basically is used to divided and network into sub-networks.
Subnetting in IPv4 is done via changing subnet mask bits, borrowing 1's from host bit portion.
/ 24 means there are 24 - 1's in subnet mask and rest all are 0's out of 32 bits.
0 - defines hosts bits
1 - defines network bits
24 is subnet mask for Class C IP Address, if you borrow more bits from it, then that network will be subnetted.
As in your example,
Network is - 192.168.1.0
Subnet Mask - 255.255.255.0
When you subnet it into /28 means from last subnet which was in binary 00000000 (eight zeros) you have converted 4 bits to one, so now subnet mask is in binary - 11110000 which is 128 (2 ^ 8) + 64 (2 ^ 7) + 32 (2 ^ 6) + 16 (2 ^ 5) = 240
Complete subnet mask becomes - 255.255.255.240
Number of subnets you got is = 2 raise to power ( ^ ) no of bits you have converted from 0 to 1 = 2 ^ 4 = 16 subnets
Number of hosts per subnet is = 2 raise to power ( ^ ) no of 0 remaining = 2 ^ 4 = 16 hosts per subnet
For verification = 16 x 16 = 256 (total hosts available with /24 subnet mask)
So your subnets will be:
Subnet No - Starting Address - Ending Address
1 - 192.168.1.0 - 192.168.1.15 (192.168.1.0 + 16 = 192.168.1.15)
2 - 192.168.1.16 - 192.168.1.31 (16 to 31 including 16 and 31 = 16 hosts)
3 - 192.168.1.32 - 192.168.1.47
4 - 192.168.1.48 - 192.168.1.63
5 - 192.168.1.64 - 192.168.1.79
6 - 192.168.1.80 - 192.168.1.95
7 - 192.168.1.96 - 192.168.1.111
8 - 192.168.1.112 - 192.168.1.127
9 - 192.168.1.128 - 192.168.1.143
10 - 192.168.1.144 - 192.168.1.159
11 - 192.168.1.160 - 192.168.1.175
12 - 192.168.1.176 - 192.168.1.191
13 - 192.168.1.192 - 192.168.1.207
14 - 192.168.1.208 - 192.168.1.223
15 - 192.168.1.224 - 192.168.1.239
16 - 192.168.1.240 - 192.168.1.255
Usable hosts are always total hosts minus two = 16 - 2 = 14 hosts (1 for Network Address and 1 for Broadcast Address)
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Another way to look at this your /24 provides 256 addresses.  The first address we normally set aside as to avoid confusion with the subnet address itself.  The last address is the broadcast address.  (NB:  /31 and /32 special cases)
When you shift the prefix by one value, you impact the address space by a power of two.
Taking a /24 and splitting it into a /25 results in two /25s each with half the addresses (i.e. 128 total with 1 for subnet, 1 for broadcast and 126 for hosts)
Taking a /25 and splitting it into a /26 results in two /26s each with half the addresses (i.e. 64 total with 1 for subnet, 1 for broadcast and 62 for hosts)
If these /26s are from the same /24, we would have four of them (or we could have one /25 and two /26s, if doing classless).
Taking a /26 and splitting into a /27 results in two /27s each with half the addresses (i.e. 32 total with 1 for subnet, 1 for broadcast and 30 for hosts)
If these /27s are from the same /24, we could have eight of them.
Lastly taking a /27 and splitting into a /28 results in two /28s each with half the addresses (i.e. 16 total with 1 for subnet, 1 for broadcast and 14 for hosts)
If these /28s are from the same /24, we would have sixteen of them.
