- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-11-2019 10:44 AM
Am I missing something? We have 5 statics, and have Comcast Business gateway. I have a Linksys Wi-Fi router connected to the router, and it is reaching the internet with the same numbers inserted in this configuration. However, I am unable to ping 8.8.8.8 from within the router (connected via putty/console).
I do plan on replacing the outdated equipment, so please do not jab too hard...
Router#sh config Using 2210 out of 262136 bytes ! ! Last configuration change at 14:53:28 UTC Thu Oct 10 2019 ! NVRAM config last updated at 14:53:30 UTC Thu Oct 10 2019 ! NVRAM config last updated at 14:53:30 UTC Thu Oct 10 2019 version 15.1 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname *** ! boot-start-marker boot-end-marker ! ! enable secret 5 ******************** enable password *** ! aaa new-model ! ! ! ! ! ! ! aaa session-id common ! ! no ipv6 cef ip source-route no ip routing no ip cef ! ! ! ip dhcp excluded-address 10.10.125.1 10.10.125.99 ! ip dhcp pool ******* network 10.10.125.0 255.255.255.0 default-router 10.10.125.1 dns-server 75.75.75.75 75.75.76.76 ! ! ip domain name ***** ip name-server 75.75.75.75 ip name-server 75.75.76.76 ! multilink bundle-name authenticated ! crypto pki token default removal timeout 0 ! ! license udi pid ****/** sn ** ! ! username *** privilege 15 secret 5 ** ! redundancy ! ! ! ! ! ! ! ! ! ! ! interface Embedded-Service-Engine0/0 no ip address no ip route-cache shutdown ! interface GigabitEthernet0/0 ip address **.**.28.249 255.255.255.248 ip flow ingress ip flow egress ip nat outside ip virtual-reassembly in no ip route-cache duplex auto speed auto no mop enabled ! interface GigabitEthernet0/1 ip address 10.10.125.1 255.255.255.0 ip flow ingress ip flow egress ip nat inside ip virtual-reassembly in no ip route-cache duplex auto speed auto no cdp enable no mop enabled ! ip forward-protocol nd ! no ip http server ip http authentication local no ip http secure-server ! ip nat inside source list 10 interface GigabitEthernet0/0 overload ip route 0.0.0.0 0.0.0.0 **.**.28.254 ! access-list 10 permit 10.10.125.0 0.0.0.255 ! ! ! ! ! snmp-server community public RO ! ! ! control-plane ! ! ! line con 0 line aux 0 line 2 no activation-character no exec transport preferred none transport input all transport output pad telnet rlogin lapb-ta mop udptn v120 ssh stopbits 1 line vty 0 4 password **** transport input ssh ! scheduler allocate 20000 1000 ntp server **.**.**.** prefer source GigabitEthernet0/0 end
Solved! Go to Solution.
- Labels:
Routing Protocols
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 12:36 PM
no ip routing
no ip cef
This does not look right. Enable both:
Router#conf t
Router(config)#ip routing
Router(config)#ip cef
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 11:30 AM
You are not able to ping from the router, But are you able to access the 8.8.8.8 from your local LAN?
from router try
ping 8.8.8.8 source 10.10.125.1
let us know is this working ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 11:35 AM
No. No internet access from behind the 1921, at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 11:55 AM
0/5 success with that, and I also tried a source of gigabitethernet0/0 (ping 8.8.8.8 source gigabitethernet0/0), which was reinterpreted as the assigned IP address, then I tried (ping 8.8.8.8 source gigabitethernet0/1), and it interpreted it as 10.10.125.1. Neither source worked.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 12:36 PM
no ip routing
no ip cef
Router#conf t
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 01:04 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2019 01:09 PM
