1T3/E3
hanwucisco
I have a 1t3/e3 card in a new 2951. When I statred the router, I found no interface corresponding to this module when do "show ip interface brief"
any idea?
thanks,
Han
2 Accepted Solutions
Edison Ortiz
If you issue show version, do you see the T3/E3 listed?
You need to configure the card type for the interface to appear.
Please refer to the documentation:
http://www.cisco.com/en/US/docs/ios-xml/ios/interface/configuration/12-4/ir-t3e3-csu-dsu.html
Han
With many of the new cards that can do both T3 and E3 they need a configuration command to tell them which way they should function. I would guess this is the case with your card. Try using the card type command and tell it whether it is to do T3 or E3. That will probably create the appropriate controller(s). And when you configure the controller with channel-group (or whatever is appropriate in your environment) then there should be serial interfaces to configure.
Give it a try and let us know the results.
Rick
Rick
Rick Morris
Level 6
Level 6
what is the output of show diag
Han
Rick
Rick
Edison Ortiz
